Rear Door Defender
I have a 300tdi sation wagon
I have purchased a second hand rear door as mine was deteriorating
I wanted the newer version door so I could have the seal around the window and the intergrated rear light
I am told that the door I have is from a tdci. How can I tell? is there any difference between a tdci and a td5?
I need to know as I need to get a new door lock and I am assuming that the tdi lock wont fit
Is there any difference between the td5 and the tdci rear lock?
Also the door has come without the rear light fitted. I have a rear light and it has two fitting holes either side as if it should screw to the rear window. There are no fittings on the rear window so are there two types of rear glass or are all the rear glass the same and I am missing a fitting kit?
Any help appreciated
Cheers
Ashley
Don't know what the differences are between a TD5 and a TDCI rear door (if any) but have a look here
http://www.landroverexpedition.com/technical/assembling-the-td5-rear-door/
good list of part numbers and a useful "how to"
The lock issue is discussed in this thread http://forums.lr4x4.com/index.php?showtopic=64861&st=20 so might be worth a read
I was thinking about going for the later style door from SP Landrovers, until I looked at how much the glass is :o
Dave
