del Posted November 23, 2012 Share Posted November 23, 2012 Just simple one , side light passenger side packed up ,changed bulb -no joy , fuse blown - changed that , now bulb lights up only when you push the bulb in hard and the goes out when released into its resting place (if you know what I mean!) . Does it need a new bulb holder? Quote Link to comment Share on other sites More sharing options...
Jim1 Posted November 23, 2012 Share Posted November 23, 2012 Mine was bad earth wire. Remove holder and check the connections may need to remake the connections. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted November 23, 2012 Share Posted November 23, 2012 Chances are the little spring in the back of the centre contact has broken or, sticking ! Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted November 23, 2012 Share Posted November 23, 2012 LR genuine and aftermarket (Britfart) side, brake/tail, indicator and reversing light internals are all carp and seem to need replacing every 5 - 7 years. The plastic internals harden and crack/disintegrate, allowing the bulb to become loose. This is possibly due to overheating, but I think the basic design and material selection are flawed. I routinely replace mine, as above. I'm now on my third set! Mike Quote Link to comment Share on other sites More sharing options...
del Posted November 24, 2012 Author Share Posted November 24, 2012 took it apart its the bulb holder , but it keeps on popping fuses - is it ok to put in a larger amp fuse? Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2012 Share Posted November 24, 2012 nope, unless you want a possible loom fire .replace the bulb holder unit, sounds like it's shorting out internally Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted November 24, 2012 Share Posted November 24, 2012 I've got all LEDs in mine, but they still fail regularly. I think the plastic on the standard lamps is a bit too biodegradable So I'm going for a pair of these next time to see if they're any better. http://www.ebay.co.uk/itm/RDX-LED-Front-Side-Light-lamp-LandRover-Defender-90-110-Series-74mm-12v-24v-/390448458061?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae88aa94d Quote Link to comment Share on other sites More sharing options...
del Posted November 24, 2012 Author Share Posted November 24, 2012 changed the bulb holder , tried a couple of 3amp fuses that blew , now im running on 8amp , What would cause the lower amp fuses to blow ? . Cant seem to get the right size fuses ,the ones from halfords are a bit to long Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2012 Share Posted November 24, 2012 the halfords glass fuse do fit, got some in my fusebox, side/tail fyse should be 5amp continuous Quote Link to comment Share on other sites More sharing options...
del Posted November 24, 2012 Author Share Posted November 24, 2012 cheers , i will give the 5amp fuses a whirl , thanks very much Quote Link to comment Share on other sites More sharing options...
