Megasquirt prob wouldn't start now sorted
Hybrid_From_Hell
This has been going on daily for 10 days, with each time him checking what I suggested
In summary
A "Racer" V8 Comp safari Full MS conversion
He advised me
It have spark,
It cranks and fast
It has fuel and has return pipe showing fuel
doesn't even try to start
No air leaks
No blockages
Correct fuel
STIM shows ECU Fine
All earths fine
new plugs leads all rechecked
wiring checked till bored with checking
changed EDIS
Ran through diagnostics, every terminal had correct volt / amps etc
no blown fuses
relays working
ECU powering
Firmware reloaded MSQ Reloaded
Ignition leads and plugs correct
so if we know:
it has right fuel
battery is fine
ecu is plugged in
coil pack wired correctly
ignition switch is fine
flywheel/starter ring is fine
rocker shafts are fitted
cam is fitted
trigger wheel and sensor are fine
the car is fully assembled..
it started before MS
has correct fuel map
timing is correct
fuel/air mixture is correct
injectors aren't sticking
engine turning correct way
all fuses fitted
has correct firing order
injectors open on correct stroke
throttle is working correctly
all wired up correctly
valves and fine
exhaust is fine
then wtf is it?! :hysterical:
lamda sensor?
:lol:
Non
20
Ok
Thus was driving me nuts - customer was a auto electrician
The wiring was perfect he said - after humouring me we rechecked
Everything .... All seemed fine
I asked him to do lots of checks all seemed fine
But nothing
I asked him to check fuel pressure answer back was masses .....
:blink:
In conversation he said he never had this prob before megasquirt
And the engine ran fine before the install
:blink:
I asked about the engine - when did it last run ?
Before I removed it - ran fine
Hmmmm
Hang on - removed it from what ?
The disco 3.9 he bought for the engine to replace
His old one ......
Any thoughts now ?
The penny clanged with me on the above last sentence
I asked him one question
What was it now then all ??
Kerching !!!!!
Old engine 3.5 carbs new engine 3.9 efi
Had twin low pressure pumps and swirl pot
He forgot to mention this
"****" we're his exact words :lol:
I said to him "how exactly did you check the bludy fuel
Pressure when I asked you ?"
"Removed the pipe and powered system fuel everywhere :D "
Hmmm 6 psi vs 30 !
Next time(s) ill be more accurate with requests !
Ho hum
