OilIT Posted September 10, 2006 Share Posted September 10, 2006 Just wanted to thank 'Dave' for the tip on the tech archive for the long studs for transfer box removal - changed the oil seal on my gearbox today - and the job was really easy !!!! Quote Link to comment Share on other sites More sharing options...
white90 Posted September 10, 2006 Share Posted September 10, 2006 yes indeed a superb tip But if you have an under drive fitted you have to remove it before trying to use long studs as there isn't the room to remove the T box with the underdrive inplace. Quote Link to comment Share on other sites More sharing options...
Coastcard Posted September 11, 2006 Share Posted September 11, 2006 the job was really easy !!!! As a matter of interest, if you are like most of us grovelling under a vehicle supported on axle stands, did you 'bench press' it out with human strength or use some mechanical assistance. I am interested as I need to do the job and am never quite sure the best way to lift/drop these things out. Ususally a lot heavier than they look!! Quote Link to comment Share on other sites More sharing options...
white90 Posted September 11, 2006 Share Posted September 11, 2006 trolley jack to aid but it isn't that heavy just awkward Quote Link to comment Share on other sites More sharing options...
OilIT Posted September 11, 2006 Author Share Posted September 11, 2006 trolley jack to aid but it isn't that heavy just awkward Bench Press (crikey!!!), sorry - I havent done anything like that for years (in fact I'm not sure I ever have) !!! No I used a trolley jack to take the weight, then wheeled the jack backwards and the tx box slid along the threaded bar (I used a 1m length of threaded bar and cut it into 1/4s as it was a LOT cheaper that way and it gave me a little bit more length from memory) This brings the tx box back far enough to remove the oil seals and replace them. Good luck ! Quote Link to comment Share on other sites More sharing options...
