oneandtwo Posted November 27, 2012 Share Posted November 27, 2012 When I turn the ignition on, the 200TDi dash voltmeter swings all the way to the right past the graduations and sits on the needle stop, engine running or not. The voltage across the terminals is 12.4V, I am guessing the voltmeter is faulty? Anyone know if they are fixable? Thanks Quote Link to comment Share on other sites More sharing options...
LiamC Posted November 27, 2012 Share Posted November 27, 2012 That does sound like its faulty, there may be some kind of internal shunt that has failed or become disconnected I prefer a volt meter that has actual voltages marked which gives a better idea of what's going on. Something like this might be a suitable replacement: http://www.ebay.co.uk/itm/12V-UNIVERSAL-BATTERY-CONDITION-VOLT-METER-GAUGE-52MM-Genuine-Durite-/230726854407?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b8646707 Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2012 Share Posted November 27, 2012 I'd say it was faulty too, my one just rose slowly to the battery or alternator output depending if engine was running or not. Quote Link to comment Share on other sites More sharing options...
jbs Posted November 27, 2012 Share Posted November 27, 2012 If I was you I would check the bracket on the rear of the gauge as I had the same problem as you describe and it turned out to be the bracket was in contact with the positive feed of the gauge and it(the bracket being earthed) was shorting out the gauge and reading as you have so accurately described. If It's not that then it'll be fubarr'd HTH John Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 27, 2012 Author Share Posted November 27, 2012 Its had it, I took it out and connected it straight to a battery and still shoots off the scale. Anyone got a spare to fill the hole? Quote Link to comment Share on other sites More sharing options...
jbs Posted November 28, 2012 Share Posted November 28, 2012 Bugger, sorry to hear that, I got my last one from Safari engineering in eversleigh-Hants as I was passing there on my way home, You could always try e-bay? Here http://www.ebay.co.uk/itm/Land-Rover-Defender-90-110-military-voltage-gauge-/110981270343?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3ALand+Rover&hash=item19d6ffcb47 HTH John Quote Link to comment Share on other sites More sharing options...
western Posted November 28, 2012 Share Posted November 28, 2012 if you can't find another LR item, the VDO Vision voltmeter is a good match got mine from Europa Spares Quote Link to comment Share on other sites More sharing options...
bluehaze Posted November 29, 2012 Share Posted November 29, 2012 Check the wiring as it could well be a poor earth. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 29, 2012 Share Posted November 29, 2012 I have a spare as i have just replaced mine with a VDO unit to match the other TD5 gauges I have fitted. PM me if interested Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 29, 2012 Share Posted November 29, 2012 Bugger, sorry to hear that, I got my last one from Safari engineering in eversleigh-Hants as I was passing there on my way home, You could always try e-bay? Here http://www.ebay.co.u...=item19d6ffcb47 HTH John Carefull that the military ones might be 24 Volt.. Quote Link to comment Share on other sites More sharing options...
