Clutch
I would guess clutch release bearing is buggered. I managed to melt mine before which resulted in this :wacko:
Agreed. Been there, done that :lol:
As JAD says, the plastic bit melts. Then it all jams up and no pedal movement is possible.
When you replace it, make sure you do the whole clutch kit while you have it apart. You'll opnly regret it if you don't.
