mmgemini Posted November 28, 2012 Share Posted November 28, 2012 http://www.memfast.co.uk/index.asp Anybody used one of these ? Any comments ? Will it be better than the Riv-Nut pliers I have now ? I know I can do the screw, nut and washer way but I'll have quite a few to fit Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 28, 2012 Share Posted November 28, 2012 I've got one, well made, easy to use and did the job, sheared the M10 tool though and replacements were out of stock for months, maybe suggests a common problem? Haven't checked for a while though to see if they were back in stock... Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted November 28, 2012 Share Posted November 28, 2012 I'm very happy with mine Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 28, 2012 Share Posted November 28, 2012 I got one of these a couple of weeks ago, so latest version. I've done over 30 so far and it's very good. Easy to use, only minor benefit would be a marker on wheel. Soon solved with a marker pen. Just went for standard set without 10mm tool for £60, as I don't do 10mm ones often and it's same price (+£25) if you order it later. Worth it for reliability of fitting in my opinion. Cheers Steve Quote Link to comment Share on other sites More sharing options...
sean f Posted November 28, 2012 Share Posted November 28, 2012 I have one and have used it extensively, very good if room is tight. Still use the more traditional lever type when room is no issue as I find it quicker and easier. If I only had one type it would be the memfast one, nice bloke to deal with as well. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted November 28, 2012 Share Posted November 28, 2012 I thought this one: http://www.ebay.co.uk/itm/400300034757?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 looked quite good. Steve Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 29, 2012 Author Share Posted November 29, 2012 I've got one, well made, easy to use and did the job, sheared the M10 tool though and replacements were out of stock for months, maybe suggests a common problem? Haven't checked for a while though to see if they were back in stock... Was it a steel or alluminium Riv-Nut that caused it to break ? Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 29, 2012 Share Posted November 29, 2012 Steel. Quote Link to comment Share on other sites More sharing options...
simonr Posted November 29, 2012 Share Posted November 29, 2012 Steve, I'm not convinced by the one on eBay. It only does tiny riv-nuts up to M6, and it's probably fine for that. The main issue is the amount of space you would need around the insert to use the tool. Most of the others have a long 'snout' which engages with the insert so you could perhaps fix an insert inside a counter-bored hole. I've used one of the MemFast tools and was quite impressed. Great for tight spaces - but I don't think it's chunky enough for M10, or at least it's going to be on the limit of the force it can withstand. I have one of the long handles types (looks like a pair of bolt croppers) and M10 is the limit of what it is rated for. My two top tips for where to buy cheap inserts are Winzur Wurth (but you need to be a company to buy from them) and Connect2 http://www.c2fasteners.co.uk/ (speak to Mike / Oliver) They are a small company and very friendly & helpful - but seem to manage to beat most of the big suppliers on cost. My Riv-Nut tool came from them 12 Years ago - and it's still going strong. Si Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 29, 2012 Author Share Posted November 29, 2012 Good coments as usual Simon. I'd want mine mainly for M4, 5 and 6, maybe the off M8 aluminium ones mostly, I think if I wanted to go M10 then the screw and nut method would suffive. Living where I do I also have a very good fastener supplier. Teeside Industrial Fasteners. They have a good stock with friendly service. I have pliers but it's getting more difficult for me to use them which is why I'm thinking of this tool. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 29, 2012 Share Posted November 29, 2012 I was surprised with the design of the inserts which neck in narrower than the thread form they are working with. It parted in this area which is where you would expect it to fail as it is the smallest CSA. I'm sure I still have the broken bit somewhere as a reminder to sort a replacement.. Quote Link to comment Share on other sites More sharing options...
