farmer_ben Posted November 29, 2012 Share Posted November 29, 2012 hi people ,right heres what happened I drove to work everything all same as useual, end of the day comes jump in the landy to go home and oil pressure light wont go out :s so left it there walked home and ordered oil pressure sender ,fitted it and light still on ? now im getting worryed ,is there any way of testing the oil pressure ??? Quote Link to comment Share on other sites More sharing options...
western Posted November 29, 2012 Share Posted November 29, 2012 have you checked the oil level ? examine oil pressure switch wire for chaffing, it maybe shorting to earth & putting the light on. you could fit a oil pressure gauge as well. Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted November 30, 2012 Author Share Posted November 30, 2012 yea it has the right amount of oil and when I pull the wire off the sender it goes out but put it back and comes on again :s Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 30, 2012 Share Posted November 30, 2012 Having experienced no oil pressure on a 300Tdi that was fitted with a proper oil pressure gauge, I suggest you get a mechanical gauge and fit it. If there is still no oil pressure then come back. Don't bother to fit the gauge into the truck. Leave it by the engine for the time being Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted November 30, 2012 Author Share Posted November 30, 2012 hi, yea this is what my mate said im trying to buy on off him atm so ill soon know ! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 30, 2012 Share Posted November 30, 2012 Ben I'm going to look on the dark side here. Should the gauge shew no oil pressure. Drop the oil and then the sump. Is the strainer full of krap ? Has the strainer fallen off the block. Any krap in the oil. The oil in mine was very clean. If no to those then front of engine off to check the oil pump. My pump had no lugs left at all where the gear runs on the crank nose. Quote Link to comment Share on other sites More sharing options...
Daan Posted November 30, 2012 Share Posted November 30, 2012 Ben I'm going to look on the dark side here. Should the gauge shew no oil pressure. Drop the oil and then the sump. Is the strainer full of krap ? Has the strainer fallen off the block. Any krap in the oil. The oil in mine was very clean. If no to those then front of engine off to check the oil pump. My pump had no lugs left at all where the gear runs on the crank nose. At what mileage is this likely to happen? Daan Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 30, 2012 Share Posted November 30, 2012 Don't know Daan. Mine happened at about 220,000 miles but others have passed that mileage without problems. In my case. as I replaced the oil pump gears to get me back across Africa in spite of the damaged crank where the pump gear runs , it's still running which now makes us think that it might have been sold to me like that. All I did was fit new pump gear and replace the bigend shells. I did drive 25 mile with little oil pressure. Quote Link to comment Share on other sites More sharing options...
Mutz Posted November 30, 2012 Share Posted November 30, 2012 I bought my 90 with very little oil pressure, but it had already been to Land Rover specialist who found it was caused by a cam bearing failure. Total strip down and rebuild. Has Excellent oil pressure now Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 2, 2012 Author Share Posted December 2, 2012 i took the sump off today and found these two washers in the sump and the spring in with the oil pressure relief valve strainer is clean so must be the pump but where are these from???????????? 1 Quote Link to comment Share on other sites More sharing options...
simonb Posted December 2, 2012 Share Posted December 2, 2012 Shifted camshaft bearings in the block, especially the rear one, can cause lack of oil pressure in 2.25/2.5 engines of all types....I don't believe there is any easy way to check though without removing the camshaft. That spring looks more likely to have come off a cheap pen than out of part of the engine though! Quote Link to comment Share on other sites More sharing options...
western Posted December 2, 2012 Share Posted December 2, 2012 you can check the rear most cam bearing by removing the rear side plate on engines right hand side to rear of FIP, you'll need a small mirror & a good torch to see if there is a gap under the rear cam bearing, done this check on my 200tdi, so it should work for you, if no gap between cam & fitting in the block the bearing hasn't moved. Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 2, 2012 Author Share Posted December 2, 2012 yea its quite a stiff spring im thinking maybey out of the fuel lift pump :-S Quote Link to comment Share on other sites More sharing options...
Hazza Posted December 3, 2012 Share Posted December 3, 2012 I found one of those nylon/plastic washers in the sump of my 200tdi last week, would love to know where it came from!? Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 3, 2012 Author Share Posted December 3, 2012 all ive been told so far is that the spring could be out of the vacume pump :-S Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 4, 2012 Share Posted December 4, 2012 So long as it isn't out of the oil pressure relief valve ... Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 10, 2012 Author Share Posted December 10, 2012 ive just fitted a new oil pump,oil pressure releif valve ,oil pressure sender and oil filter and light still isnt going out :-( any ideas ? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 11, 2012 Share Posted December 11, 2012 ive just fitted a new oil pump,oil pressure releif valve ,oil pressure sender and oil filter and light still isnt going out :-( any ideas ? Front of engine off. Look at oil pump. Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 11, 2012 Author Share Posted December 11, 2012 could it be that the oil is too thick its got 15/w40 in it ? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 11, 2012 Share Posted December 11, 2012 No I don't think so. Either camshaft bearing or oil pump. Quote Link to comment Share on other sites More sharing options...
Mutz Posted December 11, 2012 Share Posted December 11, 2012 So have you fitted a pressure gauge to see what PSI you have? Quote Link to comment Share on other sites More sharing options...
western Posted December 11, 2012 Share Posted December 11, 2012 could it be that the oil is too thick its got 15/w40 in it ? thats correct for 200 & 300Tdi engines Quote Link to comment Share on other sites More sharing options...
farmer_ben Posted December 14, 2012 Author Share Posted December 14, 2012 arr right ok im fresh out of ideas now :-( Quote Link to comment Share on other sites More sharing options...
western Posted December 14, 2012 Share Posted December 14, 2012 arr right ok im fresh out of ideas now :-( this diagnosis chart might shed some light on the faulty item diesel fault diagnosis chart.pdf Quote Link to comment Share on other sites More sharing options...
Jode Posted December 14, 2012 Share Posted December 14, 2012 this diagnosis chart might shed some light on the faulty item Thanks, Western, a very handy list! Quote Link to comment Share on other sites More sharing options...
