The electricity isn't getting to my wiper motor fast enough.....
snailracer
Having real problems with the wiper motor on cold and damp mornings. It won't work until the engine has been running for a while but once its working its fine. The neighbours are probably getting a bit annoyed at me sitting for five minutes with the engine revving before I go to work
Its a series 3 109 with a 200tdi, recently had a new loom and has no charging problems.
Anyone got any ideas?
Cheers
Matt
Is it the motor? I'd rather bet that it's either that the bundy-tube-and-wire that connects the motor to the wiper-wheelboxes is full of rust rather than grease, or that the wheelboxes themselves are seizing.
The wheelboxes in particular are a spectacularly bad design: a 'monkey-metal' aluminium alloy tube that fits through the bulkhead with a steel shaft running inside it - and no way to keep it properly lubricated. Once water gets in the gap between the spindle and the outer part, electrolytic corrosion sets in and the whole lot binds up irreversibly.
It has to be the wiper, wiring or switches (don't forget the park switch on the moror's gear box). If it was the drive mechanism (spindles or cable), then they could be seized with ice in sub-zero conditions and free up when the temperature increases, but dampness being a factor suggests electrics...
