Fuel Pipes - 300tdi Conversion
200Tdi ones will be the closest fit, 300Tdi won't fit.
Easiest route if you have a discovery breakers to hand is just buy the length of hose from tank to pump for a few quid, then you have more than enough to fit.
you could also buy regular fuel hose of the right diameter and good hose clamps.
Slightly off topic, but having owned two 110's which had been retrofitted with Tdi's, don't forget to change the header tank for a Tdi one! The NA/Td and possibly petrol tank is too small and on mine couldnt cope with the expansion of the coolant, pushing the excess out and needing constant topping up until I changed the tank!
