02920al Posted December 6, 2012 Share Posted December 6, 2012 hi, looking for assistance with my front wipers on my 05 freelander. Having a whirring noise for a few months and now ive had an issue where for 10 mins or so after starting the engine the wipers started juddering and were also very slow when on intermittant and full, and then not moving at all!!! They would work fine on max speed (3rd click) or when the lever was pushed down manually. Having had the wipers on max speed for another 5-10 mins i tried the intermitent and full and they worked as before. quite confused! I cleaned the blades as soon as they stopped working etc so i know its not that, im guessing the wipers need a new motor to solve the whirring etc. Is this an easy job for a novice? anyone seen a good tutorial/guide? I was starting to wonder if the battery may have something to do with the slow/juddering movements as it started working after 10-15 mins? warming up etc? starting to worry a bit so any advice would be fantastic! thanks all. Quote Link to comment Share on other sites More sharing options...
CJ1 Posted December 6, 2012 Share Posted December 6, 2012 Sounds like you need a new motor and possibly linkage too. Quote Link to comment Share on other sites More sharing options...
02920al Posted December 6, 2012 Author Share Posted December 6, 2012 Thanks CJ1, is that a simple/cheap enough fix do you know? Quote Link to comment Share on other sites More sharing options...
Blippie Posted December 7, 2012 Share Posted December 7, 2012 I think you get the whole assembly - wiper linkage and motor - or just the linkage. It's a simple thing to swap out with the guidance of a Haynes manual. Worth getting a set of plastic rivets for the escutcheon/scuttle under the windscreen as you'll probably foul them up removing them.. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
02920al Posted December 7, 2012 Author Share Posted December 7, 2012 Thanks! Ordered a new motor and am planning on having a play about this weekend. Thanks....... Quote Link to comment Share on other sites More sharing options...
CJ1 Posted December 7, 2012 Share Posted December 7, 2012 Thanks CJ1, is that a simple/cheap enough fix do you know? Sorry, I forgot to say, when I did mine it was a fairly easy job. Only thing that was a bit of a pain was getting the scuttle panel retaining clips out even using a screw to pop them up wasn't to easy, but once they are off the motor and linkage will be in front of you and only a couple of bolts and unplug the motor and swap it over and put it all back together. It took about half an hour and I bought a 2nd hand unit for under £20 delivered. Quote Link to comment Share on other sites More sharing options...
02920al Posted December 9, 2012 Author Share Posted December 9, 2012 Thanks again, ordered the part and now waiting for it to turn up. Had a look this weekend and was able to unscrew the scuttle panel rivots easily to my surprise!!! linkage seems good but motor still making the whirring noise when linkage detached so think I'm in the right place! Fingers crossed this will solve the problem........... Quote Link to comment Share on other sites More sharing options...
02920al Posted December 13, 2012 Author Share Posted December 13, 2012 done it!!!!! new motor really easy to fit, £50 from Britpart. saved me a fortune instead of going to nearby Land rover specialist. No noise and full movement!!! yeeeee haw!! thanks again all. Bought myself a haynes manual.................... Quote Link to comment Share on other sites More sharing options...
