FridgeFreezer Posted February 26, 2013 Share Posted February 26, 2013 I think you need to make sure you do not have a "ghost" of MegaTune running; If this is still coming, it means there is probably a crashed / locked version which is still trying to access the COM port or something. Either use task manager to find & kill it, or reboot the laptop. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 26, 2013 Author Share Posted February 26, 2013 Task manager ?? Where i find it ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 26, 2013 Share Posted February 26, 2013 Right-click on the clock in the windows task-bar -> "Start task manager" Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 26, 2013 Author Share Posted February 26, 2013 Ok task manager ; ) i try this evening Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 26, 2013 Share Posted February 26, 2013 Also pressing ctrl, shift and esc together will pop task manager up. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 26, 2013 Author Share Posted February 26, 2013 on vient de faire plusieurs essais avec plusieurs pc,donc, le mien, mega huen s ouvre une fois sur 40 000, et pas de reconnaisance de l ecu, (windows 7)celui de mon amie (vista), j ai remis le programme mega tune dessus, nickel, branchement de l adaptateur usb db9, ben connecté par intermitence via toutes les 1s, donc pas possible de gérer les paramètrescelui de mon fils, fix et xp piraté, j avais pas moyen de redemarrer megatune depuis que j avais téléchargé le programme avec, désinstalation et réinstaltion, là c est nickel, sur port db9, sur port usb rien, donc je pourrai au moins esssayé de régler mon allumage, par contre, ben il me faut un portable quand même car pour paramétrer l injection, il faut le faire en roulant, enfin , je voudrai, donc je suis à moitié baisé, mais un demi moins enculé .............****** de binaire google is your friend ,sorry, more jack this evening Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 27, 2013 Author Share Posted February 27, 2013 so, traduc mine laptop hp pavillon 7 , windows 7, no open megatune( before it was good) and so no connection via usb/db9 cable the laptop of my girlfriend, packard bell , vista, and good opening megatune, but connection via usb one second or not, so impossible to change the value, usb cable to the son computer, fix, xp pirate, reinstal megatune, now is good, db9, good, not with usb cable ........ a friend tell me to try this http://www.conradpro.fr/ce/fr/product/972497/1-port-sriecarte-Express to a another friend try to give me this old computer, if it have a db9 port .......... Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 28, 2013 Author Share Posted February 28, 2013 it's unbelievable, i have desinstalling and reinstalling megatune on my laptop, i can open all the version but no, and only not mine, MS1 extra 029v, why ?????????????????????????????????????? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 28, 2013 Share Posted February 28, 2013 What happens when you try to open it? Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 28, 2013 Author Share Posted February 28, 2013 it don't open, and if i try to open another, he tell me " another copy of megatune is already running" i just the time to see the corvette and the pub of ms, and after, nothing ....... all the another version is good .........open quickly Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 28, 2013 Author Share Posted February 28, 2013 arghhhhhhhhhhhhhhhhhhhhhhh, yes now it open, but only if i use administrator mod, this is crazy because i have try to the first time, so now is good, for how many time ?????????????????????????????????????????????? thanks a lot to us to help me, now, i will try to connect, i think i have make a good time, and do fly my laptop ......crazy, i hate computer Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 28, 2013 Author Share Posted February 28, 2013 so with my laptop, nothing with the usb so i have try with the fix to change the spark vakue, one and one http://www.servimg.com/image_preview.php?i=1352&u=11282891'> after i have try to start, but no and this is the pics where i must change the trim, but again, i have -10 cranking advance and -10 fixed angle normal ? http://www.servimg.com/image_preview.php?i=1351&u=11282891'> Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted February 28, 2013 Author Share Posted February 28, 2013 yes i have burn the value Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 i don't undertand, the engine doesn't start, i have return in the air box, and block ......; Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 in the windows spark setting i have " cranking timing" to trigger return and not time based, normal ?? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 1, 2013 Share Posted March 1, 2013 If you have the original settings from Nigel (as the ECU arrived) then you should not change them - it should be only the "basic" things needed to make it work. What happens when you try to start? Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 the engine block, and return in the air box , i have change the table all 10, i think it block less, but too again ....... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 1, 2013 Share Posted March 1, 2013 By "block" I guess you mean "backfire" (like the engine spits back at you) Try changing "trim angle = 0" Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 yes block and back fire my trim angle is at 0 do you think i can down the table to 5 or 1 to try ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 1, 2013 Share Posted March 1, 2013 Send me a data log file please to my email address Let me see whats going on in your engine and setting XLS file Start engine, Megatune File, Datalogging Record Change save location to DESKTOP Run engine and blip throttle etc 30 secs will do for now Send methe file that appears when you stop the engine Also advise of what the issues are I will look through the codes and report back Nige Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted March 1, 2013 Share Posted March 1, 2013 Bonjour, J'espère que vous ne le prenez pas mal, mais il est difficile de comprendre ce que vous dites, alors peut-être il serait mieux si vous utilisez http://translate.google.com/?sl=fr de cette façon nous serons en mesure de vous aider avec votre problème beaucoup plus facilement. Merci Chris. Hello, I hope you don't take this the wrong way, but it is hard to understand what you are saying, so perhaps it would be better if you use http://translate.google.com/?sl=fr this way we would be able to help you with your problem much more easily. Thanks Chris. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 Send me a data log file please to my email address okLet me see whats going on in your engine and setting ok XLS file Start engine, i can't, Megatune File, Datalogging Record Change save location to DESKTOP Run engine and blip throttle etc 30 secs will do for now Send methe file that appears when you stop the engine Also advise of what the issues are I will look through the codes and report back Nige but if i send you the fichier i have on my cd, this is good ?????????? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 1, 2013 Share Posted March 1, 2013 Triple check your plug wiring, for it to backfire I would think your timing is WAAAY out. Quote Link to comment Share on other sites More sharing options...
ANTOINE Posted March 1, 2013 Author Share Posted March 1, 2013 Here, my problem is that I can not start No, I think that I have too much ignition advance to, I have deans returns the air box and the engine stops after 2 or 3 motor revolutions.j I fix my ignition table 10 as freedge told me to try to start ny but I still can not,I hope that this translation will be better, thank you Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 1, 2013 Share Posted March 1, 2013 Put your engine on TDC then post up a picture of the trigger wheel and VR sensor / wheel / tooth gap as Bowie says sounds timing ! Tghere are "2" TDC, PROPER TDC where both valves on No 1 cylinder are closed and the "Other" TDC which the exhaust stroke andwill see one valve open letting exhaust gasses out Rocker cover off time - No 1 cylinder TDC + PICTURES Nige Quote Link to comment Share on other sites More sharing options...
