Leeh1306 Posted December 9, 2012 Share Posted December 9, 2012 I'm sure the answer might have been up before but I couldn't find it so I apologise. I have a 2001 td4 ES. It's started being really low powered especially when pulling off at junctions and going up hill I gave to really drive it through the rev range to get the most of it. When revving at idol the turbo lag is huge! I have done the vortex breather and the egr is removed. Help pleeeeeease! Quote Link to comment Share on other sites More sharing options...
bm52 Posted December 9, 2012 Share Posted December 9, 2012 i'd check the MAF and for loose or split turbo hoses. The right angle turbo hose by the EGR maybe the culprit. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 10, 2012 Share Posted December 10, 2012 Also check the small vacuum hoses that operate the turbo nozzle for splits/cracks. Quote Link to comment Share on other sites More sharing options...
Leeh1306 Posted December 10, 2012 Author Share Posted December 10, 2012 What do you mean by turbo nozzle? Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 11, 2012 Share Posted December 11, 2012 http://en.wikipedia.org/wiki/Variable_geometry_turbocharger There is a small solenoid valve next to the turbo which allows vacuum through to the actuator to move the nozzle & set the boost. The pipe to mine was rubbed to death. Same setup actuates the EGR valve, so worth blocking that pipe off if you've blocked/removed the EGR otherwise it'll be leaking vacuum off and potentially affecting the turbo actuator operation. Quote Link to comment Share on other sites More sharing options...
