mikec Posted December 9, 2012 Share Posted December 9, 2012 Ive just been looking at some items in my parts book and it says, when using the replacement clutch slave cylinder part number ftc5071, the spacer should be discarded. I wonder what the effects of this are, when the spacer is left on, presumable the clutch doesn't disengage quite as much? Reason I ask is I fitted one ages ago, and have just fitted a new one again both times fitting the spacer. Just wondered if this was commonly known or not?? Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2012 Share Posted December 9, 2012 never had a spacer on my slave cylinder regardless of which gearbox was fitted, I've had both LT77 & R380. Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted December 9, 2012 Share Posted December 9, 2012 This is a V8 cylinder, have you got a picture of the spacer? Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2012 Share Posted December 9, 2012 photo of it here http://www.lrseries.com/shop/product/listing/1685/591988-SEALING-GASKET.html?search=591988&page=1 Quote Link to comment Share on other sites More sharing options...
mikec Posted December 9, 2012 Author Share Posted December 9, 2012 The spacer has part number frc2402, maybe I'm confusing that with the gasket western mentioned, maybe the spacer is quite a bit thicker? Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2012 Share Posted December 9, 2012 The spacer has part number frc2402, maybe I'm confusing that with the gasket western mentioned, maybe the spacer is quite a bit thicker? http://www.thexmod.com/item_detail.asp?id=806 Quote Link to comment Share on other sites More sharing options...
