muttleyd Posted December 9, 2012 Share Posted December 9, 2012 My V8 is wired up with a combo of td5 and 200 tdi wiring. Clocks were originally td5 but after all sorts of problems decided to swap back to the older style. However the clocks don't have backlight bulb holders. Anyone know the part numbers or where I could get a suitable alternative Many Thanks Mark Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2012 Share Posted December 9, 2012 not available as seperate parts, you can use suitable grommets to hold the bulbs, I'd refit the td5 gauges they are much better. Quote Link to comment Share on other sites More sharing options...
muttleyd Posted December 9, 2012 Author Share Posted December 9, 2012 Thanks western Just had so much trouble with the temp gauge sitting at one temp and the fuel gauge playin up I decided to revert to stuff that I know matched the senders etc, Quote Link to comment Share on other sites More sharing options...
western Posted December 9, 2012 Share Posted December 9, 2012 both my td5 fuel & temp gauge are direct feed from their respective sender units. I used a 300tdi temp sender AMR1425 for the temp & the factory standard fuel sender for the fuel gauge. siminb on here has a led kit to replace the pre td5 gauge lighting, might be worth sending him a PM. Quote Link to comment Share on other sites More sharing options...
