200tdi running rough
Evening all. Last week I did the head gasket on my 200tdi and now in the morning when I start the engine it runs rough until I blip the throttle a few times then its ok. It starts straight away and when it's warmed up there's no problems. I had the head pressure tested and skimed, new set of injectors and a recon turbo. Any one had this before?
I had a similar one - rough running on one cylinder for a few seconds on cold starts. Suspected head gasket - mental note to change soon.
Eventually the engine locked solid one morning while cranking :o
Didn't find any obvious problems when I stripped it, but pressure testing showed a weep from the water jacket into #1 intake port.
