A bit of snow
q-rover
I cycled in at lunch the other day when it was wet, then cycled home in the dark when it was frozen. Was like bambi when I hit black ice on a left hand bend. Both wheels sliding, opposite lock, proper tank-slapper moment left me sat on the cross bar but still upright!
Road bikes, ice and cornering don't work well together! No idea how I didn't end up on the floor!
Went out on the mountain bike on Sunday and teh trail was thick ice, made for an nteresting ride. I don't fear crashing so much off road as I know I won't end up under a truck! Would like to try spiked tyres but we don't have the conditions that you do!
Do you go for big fat tyres to float on the snow or skinny ones to cut through?
I have these ones http://www.biketiresdirect.com/product/nokian-suomi-mount-ground-w160-studded-tire-26-inch They are only 1.9" I think even
the Nokian extreme (294 studs) is only 2.1". They're still not that good on slush covered ice going up hill. The rear wheel started slipping too much.
Its not about the skinnyness, its all about the studs ;)
I've always gone for narrow tyres when it comes to thick mud, but too thin for ice and mix ice stuff and you'll loose your footprint area, i think my studs are 1.9's too. I only use mine for xc and single track. Don't forget your tyre pressure too, i run mine right at the bottom of theire reccomended range...
Cheers for the advice. I run 1.9 rear and 2.1 front but that's contis so they are actually quite a bit smaller than their sizing compared to other manufacturers. Might be fun to try some studded tyres. Might need some for my road bike as well though!
