mmgemini Posted December 15, 2012 Share Posted December 15, 2012 Some of you may remember, some time ago I had problems with the rear door lock. The rear door lock is not repariable according to Land Rover. So I drilled the rivets out and stripped and put the lock back together. One spring wasn't right but I could still lock the door. On our last trip the lock stopped working, I didn't fancy another go at it as I had another lock without a barrell and I fitted that. That also started to play up. Never one to throw things away the original lock was still on the back of my workbench Collecting some padlocks from a locksmith I asked if he could fix the original lock. Collected lock yesterday and fitted it this morning...All hunky dory.....got a lock that works again. The cost was mininimal, a lot less then a new lock from Land Rover.... Quote Link to comment Share on other sites More sharing options...
dave88sw Posted December 15, 2012 Share Posted December 15, 2012 In my experience the only thing that breaks is the little torsion spring that holds up the locking tab, there is now a company on ebay selling the springs (£5 a pop which is a bit much for a tiny spring) but they do the job just fine. As you say you just drill out the rivets and it comes apart, i put mine back together with countersunk bolts Quote Link to comment Share on other sites More sharing options...
