Defender 300tdi side lights on independantly???
that will be DIM DIP headlights, not the normal dip beam, dim dip only operates when the engine is running, the relay senses the oil pressure signal & operates it contacts for dim dip
you can remove the relay & either fit a jumper wire as in post 11 here http://forums.lr4x4....showtopic=80272 or the more tidier solution is to fit the dummy relay as in post 13 in the same thread, item is http://www.brit-car....hp?xProd=138745
dim dip is no longer a requirement since around 2006, EU & UK repealed the requirement.
