FridgeFreezer Posted September 12, 2006 Share Posted September 12, 2006 Hammer and walnut spring to mind An over-temp switch on the motor can't be that hard to tee into the existing arrangement, and would be more meaningful than a time-related duty cycle system. I like the fridge motor idea, I've been contemplating just that when I (eventually) get my shed built. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted September 12, 2006 Share Posted September 12, 2006 Hammer and walnut spring to mind I like the fridge motor idea, I've been contemplating just that when I (eventually) get my shed built. Give me a shout nearer the time, there's a lot more to it than meets the eye! and I'll bet you'll be begging for a sledge hammer to crack your nuts! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 12, 2006 Author Share Posted September 12, 2006 Roger and I have been chatting through quite a few things, it's not nearly as simple as it appears. Besides, what's the problem with having a little bit of fun :) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 12, 2006 Share Posted September 12, 2006 I suppose you may win the "Most obfuscated engineering contest" If you wanna do it that way and enjoy the challenge then I'm not knocking it, just personally I like to keep stuff (relatively) simple, and using a PC to control your air compressor does not fall into "simple" in my book Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted September 12, 2006 Author Share Posted September 12, 2006 I see what you mean, and the 'simple' still remains, by design. Use the manual valves, unplug the PC controlled relay, and plug the 'normal' compressor plug back in, and voila! one failsafe system. Bit like what's in the landrover, that has overides so if the PC throws a fruit loop the whole lot can be manually controlled. onboard ITX and megasquirt - i'm looking forward to that one :D Luke Quote Link to comment Share on other sites More sharing options...
rtbarton Posted September 12, 2006 Share Posted September 12, 2006 ..just personally I like to keep stuff (relatively) simple, and using a PC to control your air compressor does not fall into "simple" in my book Wait until you start using fridge compressors Quote Link to comment Share on other sites More sharing options...
