Door Gaps...
need4speed
Many of you have probably heard this before, but i thought it needed refreshing.....
Just a quick note regarding shut lines on a Land Rover Defender . . .
In the early 80's it was widely reported that Mitsubishi wanted to test the effectiveness of the door seals on the Shogun both to prevent water ingress during wading and to keep out the sand when entering the various desert races they had entered. All their measuring equipment proved inconclusive so they locked a cat into the vehicle and went away for a few hours. When they later returned the cat had suffocated, neatly proving that the air-tight security of the Sogun was satisfactory.
Not wanting to be outdone the men-in-brown-overalls at Solihull decided to try the same experiment with the (then) new 90 and 110. A scraggy moggy was obtained and locked into a Land Rover fresh of the line. The engineers firstly ensured that all doors and windows were firmly closed then went to lunch.
When they returned the cat had escaped!
