DAN82SED Posted December 20, 2012 Share Posted December 20, 2012 Alright guys, hopeful someone might be able to shed some light on why my 98 disco won't start Was driving fine then the engine cut out and wouldn't restart The ow plug light won't come on now and fuel doesn't seem to be getting past the stop solenoid I ran a cable to the battery and the glow plug light came on but still wouldn't start The engine turns over fine but doesn't seam to be getting fuel I've pulled the dash apart to fit a spider bypass only to discover there wasn't one Any ideas? The engine overheated about 3hrs before it died but drove fine once cooled and topped up so I don't think it is related Any help greatly appreciated Cheers dan Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted December 20, 2012 Share Posted December 20, 2012 Have you checked the fuel stop solenoid for functionality as the pin could be stuck of the feed wire may have come loose? Steve Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 20, 2012 Share Posted December 20, 2012 Is it an ECU version? Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 20, 2012 Author Share Posted December 20, 2012 I'm going to remove and clean connections this evening. When I wired it direct to battery it was clicking so presume its working. Not to sure as to whether it is ecu or edc?? a bit confused about the whole immobiliser location Will take a photo tonight Would the glow plug light not coming on be linked to the fuel solenoid? Cheers Dan Quote Link to comment Share on other sites More sharing options...
omer67 Posted December 20, 2012 Share Posted December 20, 2012 I dont want to scared you, but you have to look camshaft drive belt. Some times ago I have the same problem with my disco 200 TDi Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 20, 2012 Author Share Posted December 20, 2012 Right Pretty sure its the immobiliser.Just checked if there is power to the fuel solenoid and there's not. It's a 3 pin but 2 of the wires have been pulled out by previous owner by the look of it. One of the loose cables is showing 10v but the one connected to the solenoid has no power. Still can't find the ecu. Any ideas how to fix it when I find it? Quote Link to comment Share on other sites More sharing options...
Niamh Posted December 20, 2012 Share Posted December 20, 2012 Remove the solenoid and take off the pin and spring and put the solonoid back. Will it start then? NB the only way to stop the engine having done this is to stall it. Niamh Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 20, 2012 Share Posted December 20, 2012 Use a wire with a female spade terminal directly from the battery to the solenoid and try starting it. This will tell you if it's something between the immobiliser and solenoid. Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 20, 2012 Author Share Posted December 20, 2012 Just tried starting it again with a direct cable from solenod to battery still wouldn't start. This time noticed that if I shook the cable to the battery the glow plug light would go on and off. If I left the cable connected the glow plug light would stay off. Any ideas? Will have to wait till tomorrow to remove the solenoid. Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 21, 2012 Author Share Posted December 21, 2012 Bit of progress today. Changed the solenoid and hot wired it and the engine started. Defiantly an electrical issue but still none the wiser. Any electrical wizards got any ideas. Gonna start pullin the loom apart tomorrow. Still got no power to pump or glow plugs Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 22, 2012 Share Posted December 22, 2012 I think it might be a problem with the ignition switch or both of the relays controlled by them. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 22, 2012 Share Posted December 22, 2012 Bit of progress today. Changed the solenoid and hot wired it and the engine started. Defiantly an electrical issue but still none the wiser. Any electrical wizards got any ideas. Gonna start pullin the loom apart tomorrow. Still got no power to pump or glow plugs You're probably on to it there. A friend had a camper van once, I forget now what make it was, but it had a similar setup to the TDi's in that it had a fuel solenoid on the pump to stop the fuel. When he bought the van the PO gave him a can of easystart and said it was occasionally a tempramental starter. One day while we were out camping it refused to start, towed it round the field it wouldn't start. I eventually started looking at the electrics and jumped the solenoid from the ciggy socket. The voltage at the solenoid was well down. I think what was happening was that the volts were being lost in the loom, and the solenoid wouldn't open. By squirting easystart up the air intake the engine would start, the alternator would kick in and raise the voltage enough to open the solenoid, and then it would run on fuel. Took a new fused feed off the battery to a spare switch on the dash, then on to the solenoid, and the thing never failed to start again....well not while he had it anyway...apparently the new owner didn't like that...but what they did about I don't know. Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 22, 2012 Author Share Posted December 22, 2012 Thanks for everyone's help. Not going to have the time to investigate anymore until after Xmas now. As soon as ive had a good root around I'll post my findings. No doubt I'll needed more help Cheers guys Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted December 26, 2012 Author Share Posted December 26, 2012 problem sorted, it was the solenoid but only just remembered that when i was messing about with it i forgot to disconnect the battery and when i connected it, it sparked. checked the fuses again and sure enough found the culpret. All this over a 10A fuse. thanks for everyone imput Quote Link to comment Share on other sites More sharing options...
