Dual Tank Valve
ajh
I think I follow you.
Your 2.25 only has a feed and no return from being a carb vehicle correct?
For the 200tdi you have 2 options if you have 2 tanks.
One is using 2, 3 way valves to send the feeds and returns back to the tanks.
Second is to loop the return back into the feed on the engine side of the valve using just one 3 way valve. But this can have issues with air locks.
