Kierran.M.110 Posted December 20, 2012 Share Posted December 20, 2012 would anybody know what coloured wires go to which terminal on the ignition switch below. it is numbered 1, 2, 3, 4 number 2 has the double spade terminal, cheers. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 20, 2012 Share Posted December 20, 2012 What model truck? Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted December 20, 2012 Author Share Posted December 20, 2012 its a 1989 110 that i believe had a 2.5 petrol at one time but now has an iveco 2.5td Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 21, 2012 Share Posted December 21, 2012 1 would normally be power in, after that a meter can tell you which terminals are live when. I would have expected bigger terminals for the main power in, but that doesn't seem to have them, thats perhaps something to do with the modernisation of electrics, like thinwall cable Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 21, 2012 Share Posted December 21, 2012 1 would normally be power in, after that a meter can tell you which terminals are live when. I would have expected bigger terminals for the main power in, but that doesn't seem to have them, thats perhaps something to do with the modernisation of electrics, like thinwall cable Could be two power in cables Quote Link to comment Share on other sites More sharing options...
western Posted December 21, 2012 Share Posted December 21, 2012 this info might help it's for a 200tdi ign switch http://forums.lr4x4.com/index.php?showtopic=9354&hl=+200tdi%20+ignition%20+switch%20+wiring#entry98615 any makers part/model numbers/terminal idents on your new swwitch ?? Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted December 21, 2012 Author Share Posted December 21, 2012 there is two heavy wires one is brown and one is brown with a red trace. i do have a connecting wire which converts the large wire size to the terminal size on the ignition switch. i do have a heavy white wire and 3 smaller wires which are white, one has a red trace one has an orange trace and one has a black trace,most people i speak to have the igntion switch that is black and has the 5 terminals, cheers for the replys Quote Link to comment Share on other sites More sharing options...
western Posted December 21, 2012 Share Posted December 21, 2012 plain brown is 12v feed direct from battery brown/red trace is the old TD engines glowplug feed no timer relay. plain white is ign switched live feeds white/red trace is starter motor feed white/orange trace is air condition motor feed [if fitted] again ign switch controlled white/black trace is 12v feed to fuel stop soleniod on Injection pump. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 21, 2012 Share Posted December 21, 2012 yup, sounds exactly like the TD wiring I was replacing with TDi wiring the other week. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted December 21, 2012 Author Share Posted December 21, 2012 cheers for that western, just have to find which terminal each one goes, i cant seem to get any reading when switched with a multimeter though. Quote Link to comment Share on other sites More sharing options...
western Posted December 21, 2012 Share Posted December 21, 2012 shove a diagram on here of the rear face & terminal numbers/idents, maybe we can sort it out. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted December 21, 2012 Author Share Posted December 21, 2012 will do, it looks like a 300tdi ignition switch but not sure if it is though Quote Link to comment Share on other sites More sharing options...
western Posted December 21, 2012 Share Posted December 21, 2012 have a look here http://www.legionlandrover.com/manuales/electrical%20schemes%20-%20defender%20300%20tdi.pdf 1st diagram 'power distribution' ign switch in left centre of diagram, you can zoom in to get a better view. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted December 21, 2012 Author Share Posted December 21, 2012 will take a look at that. i have just tried uploading a diagram and a few pics but it aint letting me at the minute. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 9, 2013 Author Share Posted May 9, 2013 finally i have got the engine to turn over but had to take all black tape/conduit of the loom to find the right wires but the wire coming from the starter changes colour in the middle of the loom to a large white with red trace this wire then goes into a relay and when the correct wires are connected to the ignition nothing happens. when i by-pass this realy and extend this wire back to the igniton in replace of the small white with red trace the engine will turn over nicely, i cannot understand what this realy does, pic of the relay below (right relay) Quote Link to comment Share on other sites More sharing options...
western Posted May 9, 2013 Share Posted May 9, 2013 thats the start relay, it allows thin wires to do the control in the cab & gives battery volts to the starter motor soleniod via the thicker wires, if it doesn't work try swapping it with the brake check relay next to it. Quote Link to comment Share on other sites More sharing options...
western Posted May 9, 2013 Share Posted May 9, 2013 also within the main loom, there are 2 multiplugs one is for petrol engined vehicles & 2nd for diesel engined vehicles, make sure you are connected to the corect one, wiring diagram will tell you what wire colours to look for. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 9, 2013 Author Share Posted May 9, 2013 cheers will have a look in the morning Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 9, 2013 Author Share Posted May 9, 2013 you wouldnt be able to point me in a more specific direction for that multiplug would you, cheers Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 next to brake servo where the loom joins to engine & chassis looms, Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 10, 2013 Author Share Posted May 10, 2013 there was only one connector and nothing that would fit into it Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 strange there aren't any empty plugs, my 110 is a 89 too, what wiring diagrams are you using LR or Haynes ?? Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 10, 2013 Author Share Posted May 10, 2013 haynes they dont seem to show much but then i dont realy know what im lookin at when it comes to wiring diagrams. there is one spare connector and nothing that will connect to it. i had a go at swapping the relay and no luck, i also found another relay in the garage and tried that and no luck, it is ready to fire up once i fit the exhaust and put in diesel but i dont really want to do it without the electrics being right. Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 10, 2013 Author Share Posted May 10, 2013 it also doesnt help that wire colours change from the engine back into the loom from when the engine was changed Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 I'll add the wiring diagrams I use tomorrow, it's just a map really, the colour codes can be treated like bus routes from the start to the end, Quote Link to comment Share on other sites More sharing options...
