Td5 ECU and Throttle Pedal
Hi,
Having some strange issues with my truck, and believe it may be wires between ECU and throttle pedal. So I need to check/replace wiring between the two.
Having looked into this, these are what I believe are correct, but if someone can confirm or correct, please do.
Black ECU plug
ECU pin 12 - white green - pedal connector F - sensor 1
ECU pin 36 - white grey - pedal connector K - sensor 2
ECU pin 26 - black yellow - pedal connector D - earth
As above - black yellow - pedal connector G - earth
ECU pin 20 - red green - pedal connector C - unknown
ECU pin 14 - white purple - pedal connector B - supply 5v
As above - white purple - pedal connector J - supply 5v
Any help much appreciated
Andy
