Engine Warning light, help needed.....
tjolliffe
Hi All,
Some advice/help needed if at all possible. The Check Engine light has come on on my disco. It's an 96 EDC Auto 300. The light is on but not as bright as when you first start the car (if that makes sense? Ie. when all the dash lights turn on on start up).
Everything is working fine. Engine is running smooth, no loss of power and auto box is working as it should. I have checked all fluid levels.
Only odd thing is that the two little lights that light up the gear selector positions have also stopped working (the bulbs are not blown).
Any help would be greatly appreciated!
Tom
