another problem???? tunnel
hi all
it seems to be 1 thing after another
prob this time is the gearbox tunnel not fitting properly???
i have used the seatboxes tunnel and bulkhead from td5
i am useing origanal 200tdi engine box the small bellhousing type
and the chassis
but the gearbox seems to be couple of inches to far back
i will try posting pics
regards
mike
post-34713-0-55004300-1356190060_thumb.jpgpost-34713-0-47132200-1356190104_thumb.jpgpost-34713-0-94435100-1356190145_thumb.jpgpost-34713-0-00141900-1356190292_thumb.jpg
Fireblade, get a lt77 tunnel and flange to bolt on to the bulkhead, then modify your seat box to suit the lt77 tunnel by removing the flange and making a new one. You'll find that the lt77 tunnel is narrower so your handbrake will stay closer to your leg.
Personally, when I discovered this in circumstances similar to your own, I got hold of an earlier seat box in decent nick and used that.
For matting, I used an lt77 tunnel mat with the floor mat portions from the r380 floor/tunnel mat. It's not perfect but good enough for me :)
HTH
Mo
Yeah sounds like you went the wrong way unfortuantly, you should have used an LT77 tunnel cover, and modified your seat box to fit. I've got a 200tdi with an r380 (shorty) fits perfectly with the LT77 set-up.
similar in my 110, 200tdi/stumpy R380 original TD/LT77 seatbox & tunnel parts.
