animal Posted December 25, 2012 Share Posted December 25, 2012 hi i have a 1988 v8 130 land rover fitted with a mechanical pto driven superwinch i think its 525, as i am goint to convert this to a 200tdi with lt77/ gearbox will my pto drive fit the new gearbox. thanks for your time Animal Quote Link to comment Share on other sites More sharing options...
western Posted December 25, 2012 Share Posted December 25, 2012 PTO unit fits on the Transfer box not the main gearbox but depends on which main gearbox you have behind the existing V8, if you have an existing LT230 transfer box, the PTO should be OK. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted December 26, 2012 Share Posted December 26, 2012 Also the routing of the shafts may be affected. Quote Link to comment Share on other sites More sharing options...
kingrat Posted December 27, 2012 Share Posted December 27, 2012 I fitted that winch and shaft combination to a TD5. It only required slight work on the drive shafts and brackets to get it to route and work correctly. Quote Link to comment Share on other sites More sharing options...
