ELVIS Posted December 25, 2012 Share Posted December 25, 2012 Hope ive called it by the right nem, would be a sill on any other vehicle!! The sill that runs from the A to C pillar appears to be held on with a bit of luck and chequer plate riveted over the top (although the whole thing is a bit wobbly). One presumes underneath there is a proper bit of metal that connects the outriggers. Is this bolted on or weld on? easy to do? parts available? erm, anything else i need to know? When you open passenger doors the sill tops look distinctly crusty and has a good 'explosion' for want of a better word,of tiger seal trowled on over the top. Quote Link to comment Share on other sites More sharing options...
ELVIS Posted December 25, 2012 Author Share Posted December 25, 2012 http://www.yrmlandrover.com/epages/BT3575.sf/en_GB/?ObjectPath=/Shops/BT3575/Products/070/SubProducts/070-0001 i guess these might be whats lurking underneath body/ali ? Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted December 25, 2012 Share Posted December 25, 2012 its the fixings are: 2 bolts on the bulkhead out rigger 6 spot welds on the B pillar 2 bolts on the seat belt anchorage point 6 spot welds on the C pillar 2 bolts on the mid cross member and a few bolts on the floor panels. best way to remove is with an 7mm drill bit, a hammer and chisel. http://www.yrmlandro...oducts/070-0001 http://www.yrmlandro...oducts/071-0001 as this is a job i have completed as mine were no the best... , i would surgest using the company above, there very good and parts are very accurate. good luck. Quote Link to comment Share on other sites More sharing options...
western Posted December 25, 2012 Share Posted December 25, 2012 correct, I replaced both channels on mine a while ago with rectangular box & repair the sloping part too. Quote Link to comment Share on other sites More sharing options...
ELVIS Posted December 25, 2012 Author Share Posted December 25, 2012 Cheers (as ever) forum chaps! Retired/medicalled off last year and am now the worlds oldest apprentice at 40 (although technically i guess im the unskilled partner) at my mates/our bodyshop. Flat out on old VWs but looks like landies might start to feature heavily cheers again Elvis Quote Link to comment Share on other sites More sharing options...
