white90 Posted September 6, 2005 Share Posted September 6, 2005 I got the PDAMODS.com one and promptly sent it back as it was a poor quality then I spoke with the RAM chap he advised on what to buy I had to modify it as I'm using a CF gps but Chris Watts gave me some Velcro which fixes it just fine. the suction mount is very strong and despite hitting a tree at 10mph then very rough terrain hasn't moved a mm Quote Link to comment Share on other sites More sharing options...
M005 Posted September 6, 2005 Share Posted September 6, 2005 Looking good Tony, I assume you have everything working now Is there much movement of the PDA when you are dring along ie. It shaking around? I assume you got it direct from RAM? Quote Link to comment Share on other sites More sharing options...
John_T Posted September 6, 2005 Share Posted September 6, 2005 I struggled with this problem for a while and solved it by getting a (Norwegian made) custom mounting bracket for the Defender. It fixes by fitting under one of the windscreen heater vent screws at the top and one of the fixing screws under the dash panel. Like Tony the actual PDA is attached by velcro. When in place you can't actually see the mounting bracket. It does not shake at all due to being firmly fixed to the dash (without making any holes!). Sorry don't have any pics of the braket on its own to hand but here is the end result. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 7, 2005 Author Share Posted September 7, 2005 Mark no it is fine, it came from gpswarehouse cost approx £38 all working fine with thanks to: Mark90 Chris Watts M_murphy Les Brock Bish bosh M005 Darth Dicky for all thier help in choosing setting up and installing the device. total cost: PDA £317 PCworld mount £38 GPS warehouse CF gps/external antenna ebay £45 Sd card Ebay 1gb £45 power cable Fone cables ebay £5 x3 lots of screen protectors they are sods to get right, I ruined 4 before I got one on satisfactorily £14 Quote Link to comment Share on other sites More sharing options...
