bluespanner Posted December 28, 2012 Share Posted December 28, 2012 Can I get away without an oil cooler? Or does it desperately need one for some reason. Quote Link to comment Share on other sites More sharing options...
discomikey Posted December 28, 2012 Share Posted December 28, 2012 you can get away without one, but why? if you work it hard, without an oil cooler you will get high EGT's which aint really too good for the engine, im running with the cooler blanked off for now as my filter housing broke, and i swapped it for a series engine filter and housing. but its not ideal for how much i work it. and youve gotta think.. if it didnt really need one, why did Land Rover put one in? okay, they tested them in pretty extreme conditions, but nothing that couldnt be achieved by one of us.. p.s. i take it this is for some kind of engine conversion? Quote Link to comment Share on other sites More sharing options...
western Posted December 28, 2012 Share Posted December 28, 2012 the turbo charged engines have oil coolers to help cool the turbo bearings/engine oil to keep the overall temps in a desired range, if the oil cooler is removed the result could be overcooked turbo bearings & other engine damage. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 28, 2012 Share Posted December 28, 2012 Because the rad was in the back of the tomcat I used a copper tube zig zaged several times behind the intercooler worked well in fact BMW use this system on there cars i would however change the oil more often . Mike Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 28, 2012 Share Posted December 28, 2012 Dont forget if you remove the cooler and blank the ports on the filter head you must remove the oil stat in the fliter head. Quote Link to comment Share on other sites More sharing options...
bluespanner Posted December 28, 2012 Author Share Posted December 28, 2012 Why is that Phil? Quote Link to comment Share on other sites More sharing options...
Spongie Posted December 28, 2012 Share Posted December 28, 2012 as the oil wont be able to circulate around. Quote Link to comment Share on other sites More sharing options...
western Posted December 28, 2012 Share Posted December 28, 2012 the hose will have to be removed & the ports on oil filter head blanked too, removing or leaving the oil stat won't make any difference Quote Link to comment Share on other sites More sharing options...
Spongie Posted December 28, 2012 Share Posted December 28, 2012 Scrap what I said last, was misreading the post I think. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 29, 2012 Share Posted December 29, 2012 the hose will have to be removed & the ports on oil filter head blanked too, removing or leaving the oil stat won't make any difference With the ports blanked you are correct that it wont make any difference when the oil is not hot. But when its hot and the stat opens to divert the oil thro the cooler because it has been blanked off will mean that the oil flow to the engine bearings will stop or be very very reduced, result one toast engine. Quote Link to comment Share on other sites More sharing options...
western Posted December 29, 2012 Share Posted December 29, 2012 With the ports blanked you are correct that it wont make any difference when the oil is not hot. But when its hot and the stat opens to divert the oil thro the cooler because it has been blanked off will mean that the oil flow to the engine bearings will stop or be very very reduced, result one toast engine. but if the oil cooler is removed, there's no need for the oil stat or hoses from oil filter head to oil cooler Quote Link to comment Share on other sites More sharing options...
bluespanner Posted December 29, 2012 Author Share Posted December 29, 2012 Do the question is, does the stat divert 100% oil to the cooler or does it just give it the option? Quote Link to comment Share on other sites More sharing options...
western Posted December 29, 2012 Share Posted December 29, 2012 the stat opens @ 74 degrees, not sure how much [quanity] of oil actually flows via the cooler. Quote Link to comment Share on other sites More sharing options...
