hsf Posted December 28, 2012 Share Posted December 28, 2012 Hi firstly wish you all a healthy happy and prosperous new year, nipper has asked me to renew the antiroll bushes front and back on his td5 diesel, havent had anything to do with landys apart from head gasket (suprise suprise) on a freelander, are these straight forward or any tricks of the trade to speed the job up? I havent checked it out but local garage reckons need doing and want to charge £250..,personally I would be suprised if they all need changing ?is this common, thanks and regards. Quote Link to comment Share on other sites More sharing options...
hsf Posted January 1, 2013 Author Share Posted January 1, 2013 I realise this isnt earth shatteringly interesting but a few helpfull replies would be appreciated ! cheers Quote Link to comment Share on other sites More sharing options...
bm52 Posted January 1, 2013 Share Posted January 1, 2013 check out super pro bushes. swapped mind a while ago and they are much better than the standard ones IMHO Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 2, 2013 Share Posted January 2, 2013 £250 is ridiculous. I've not changed any but mine have been done and they are a weakness - other bushes last much longer. I don't think they are too hard though. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 2, 2013 Share Posted January 2, 2013 It's an easy job! Contrary to other posts about PU bushings, I think they are worthwhile on anti roll bars. The additional stiffness is an advantage. If you go the Polyurethane bush route, I'd recommend SuperPro. I'd not recommend PU for any of the other bushes though. The hardest part of the job is getting the nuts & bolts undone. Spray them with WD40 or similar a day before you do the job and again when you are doing it. It only takes an hour or so worst case. Si Quote Link to comment Share on other sites More sharing options...
andy2986 Posted January 2, 2013 Share Posted January 2, 2013 Ive Put super Pro bushes on the front of my Disco, easy job hardest part was taking the old bolts off. I used new bolts to put the arbs back on. Andy Quote Link to comment Share on other sites More sharing options...
hsf Posted January 2, 2013 Author Share Posted January 2, 2013 Thanks guys,so go super pro seems to be the way....so next question ebay ? or can you recomend stockist,thanks in advance. Quote Link to comment Share on other sites More sharing options...
simonr Posted January 2, 2013 Share Posted January 2, 2013 eBay are normally more expensive! I'd try Difflock.com or SuperPro Europe who are based in the west country, directly (though they may not sell direct to the public). Si Quote Link to comment Share on other sites More sharing options...
andy2986 Posted January 2, 2013 Share Posted January 2, 2013 I got mine from QT Services Quote Link to comment Share on other sites More sharing options...
hsf Posted January 3, 2013 Author Share Posted January 3, 2013 Cheers guys, its nippers truck so I will pass on your advice its up to him which bushes he buys but I will let you know some when along the line when we get a chance to fit them how it went, already got him spraying the bolts with wd 40. thanks Quote Link to comment Share on other sites More sharing options...
