Reg Posted December 29, 2012 Share Posted December 29, 2012 My rangie has been laid up for a time and was down on the stops having been left gathering dust. When I fired it up and reset the windows etc I took it round the block but the suspension refused to budge. A check on the diagnostics box showed both offside sensors out of limits. The compressor was persuaded into life but it still failed to respond. I gave up and ordered a set of airline over ride valves and started pricing height sensors; then had a little brainwave. Trolley jack under offside sill, jacked up untill both wheels were hanging free. Then fired up the engine, wherupon the nearside rose to meet the height of the offside on the jack and when I dropped the jack the offside pumped up to match. This may not be an original idea but it certainly solved the sensor issues. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 31, 2012 Share Posted December 31, 2012 What often happens is that people drive off with the car on the bumpstops.When you do this a big bump or pothole will crush a bumpstop and allow the axle to move closer to the chassis than it normally can.The EAS ecu then sees a return from that sensor which is beyond what it normally sees - a fault is then logged. I always advise owners to fire the car up with the door open for five mins or so,this allows enough pressure in the system to get the car off the ground when you close the door before driving away. Quote Link to comment Share on other sites More sharing options...
rampant range Posted December 31, 2012 Share Posted December 31, 2012 have you tried http://www.rswsolutions.com/index.php?option=com_content&view=article&id=53&Itemid=56 it is a free software but supposed to be really good Quote Link to comment Share on other sites More sharing options...
