mikec Posted December 30, 2012 Share Posted December 30, 2012 Hi guys I'm looking at buying a used ms. I'm a little unsure on a couple of things, firstly do all ms kits have the ability to change maps or is it something that has to be "built in" to the ecu, the second question is the same but regarding tach output? If any adults could help me out that'd be great, :0 cheers mike Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 30, 2012 Share Posted December 30, 2012 Yes MS1 and MS2 have switchable MAPs for both spark and fuel etc, as std via PC Loading or can be done via external switch with ECU Mods. Same on Tacho out - see sams thread Nige Quote Link to comment Share on other sites More sharing options...
mikec Posted December 31, 2012 Author Share Posted December 31, 2012 Ok cheers Nige what about lambda sensor, this kit has no lambda wiring as the guy didn't bother with it, will the be a problem or is it quite straight forward? Cheers again mike Quote Link to comment Share on other sites More sharing options...
iomlt Posted December 31, 2012 Share Posted December 31, 2012 should be easy to through in the etra 4 wires ( 2 heaters 1 earth and 1 signal) there is a very good kit forsale all built up at the moment in the forsale section. Quote Link to comment Share on other sites More sharing options...
mikec Posted December 31, 2012 Author Share Posted December 31, 2012 Ok cheers guys what about the map vs tps? Is there any advantage of either or any advantage having both? Cheers mike Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 31, 2012 Share Posted December 31, 2012 They are both INPUTS to the ecu and are both needed Nige PS Lambda easy, have a lookie at the new revised website, around 50+ hours now of recoding and work, some from a grown up web chap mate HUGE amount on top from me LAmbda is connect up, as ECU will find it as remap ill have settings in, buy the Kit and then we can sort out whats what etc Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted December 31, 2012 Share Posted December 31, 2012 Whoever buys this kit can expect support from me as if just bought a new kit. Tis the way I work Theres nothing thats not going to be an easy fix, nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 2, 2013 Share Posted January 2, 2013 Wait wait wait! - MAP switching needs hardware modifications inside the unit. As do the other "extra" things like fan control, shift lights and whatnot. Not a problem to do, but you need to be sure of what you're buying. Also be aware that different ignition setups need modifications inside the ECU too - if it's set up for distributor and you want to use EDIS you need to make mods, likewise for a PWM idle valve. Quote Link to comment Share on other sites More sharing options...
Rob_B Posted January 3, 2013 Share Posted January 3, 2013 How much difference does it make if this is a v2.2 or v3 board? Just ask this as the OP doesn't say what board it is. May be some thing he should check. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 3, 2013 Share Posted January 3, 2013 V3 is more robust, easier to modify for EDIS, but not so much as to be worth worrying about overly - I ran V2.2 for years and they're fine. More tricky to add PWM idle valve to a V2.2 board from memory. Quote Link to comment Share on other sites More sharing options...
