1987 90 wiper issue
did try having a search but couldnt find anything relevant to my problem, the wipers are currently working and work at 2 speeds, the issue is they seem very laboured (driven old 90's before so know what they should be like) they also making quite a loud 'click' at about 45 degrees which sounds like its coming from the spindles rather than the motor. Any ideas?
when you've got the blades & arms off, put a blob of paint at 12o'clock on the wheelbox shaft, after you extract the wiper motor/cable, note where the paint blob is, before putting the cable/motor back, rotate the shafts 1/2 turn, hopefully when the cable is refitted it'll be driving on a less worn part of the wheelbox gear.
