thebiglad Posted January 3, 2013 Share Posted January 3, 2013 I'm going to be having a look at a mates Disco TDi 300 auto tomorrow (1997) because it has a lighting fault.No rear side lights, no front side lights, no dashboard lights.Brake lights work, reverse lights work, headlights main and dip all work.I checked the engine bay fuses, but that's all up to now.My plan is to check the cabin fuses, but then I'm not sure where to check.Any and all ideas welcome.CheersDave Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 3, 2013 Share Posted January 3, 2013 Just having a very quick glance at the wiring diagram, seems the lighting switch feeds fuses 2 and 8 (F2 & F8) in the passenger fuse box so check those. If they're fine try taking a live feed to them and see if the lights come on, if so it could be the contacts have failed in the sidelight side of the lighting switch. I presume by dashboard lights you mean the back lighting and not the warning lights themselves? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted January 3, 2013 Share Posted January 3, 2013 I concur with ejparrott, had the same issue on my 300Tdi Defender and was a fuse blown in the cabin (indicators went as well). Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 7, 2013 Share Posted January 7, 2013 Any good? Quote Link to comment Share on other sites More sharing options...
