Retroanaconda Posted January 4, 2013 Share Posted January 4, 2013 That's what mine had. But so long as the connection between the dash duct and the heater box is sealed both sides of the bulkhead you'll be fine Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 4, 2013 Author Share Posted January 4, 2013 Here you go... Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2013 Share Posted January 4, 2013 AFAIK the seal stc952 or stc953 item 2 inhttp://www.numcat.ru/landrover/p/31/52982/ fits on the heater box duct then it squashes against the bulkhead with items 23 & 24 in http://www.numcat.ru/landrover/p/31/53604/ on the cab interior side between lower dash duct & bulkhead. item 23 is know by LR as a bezel Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 4, 2013 Author Share Posted January 4, 2013 Now that is a blanking plate that fits into bulkhead heater hole. Why i dont know Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 4, 2013 Share Posted January 4, 2013 How strange. Fair enough, it's definitely a plate! The part I describe must be part of the dash duct then. A simple way of creating a lip to centre it in the hole perhaps. Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2013 Share Posted January 4, 2013 Now that is a blanking plate that fits into bulkhead heater hole. Why i dont know might be a blanking plate for use on LHD vehicles where the heater & dash is opposite sides. Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 4, 2013 Author Share Posted January 4, 2013 James i was like you. I though at first it must be a frame. Thats why i (mistakenly) ordered it lol Quote Link to comment Share on other sites More sharing options...
mikec Posted January 4, 2013 Share Posted January 4, 2013 How strange. Fair enough, it's definitely a plate! The part I describe must be part of the dash duct then. A simple way of creating a lip to centre it in the hole perhaps. I know the bit your on about mate, mine had one on an '86. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 4, 2013 Share Posted January 4, 2013 mmm note to self, do not order that plate if i wanna keep warm. Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2013 Share Posted January 4, 2013 might be a blanking plate for use on LHD vehicles where the heater & dash is opposite sides. it's no for the job above, there's another plate to blank the heater hole, Quote Link to comment Share on other sites More sharing options...
mikec Posted January 4, 2013 Share Posted January 4, 2013 it's no for the job above, there's another plate to blank the heater hole, Is it something to do with air on being fitted? Quote Link to comment Share on other sites More sharing options...
ross_north Posted April 21, 2014 Share Posted April 21, 2014 Having just repaired my heater box and refitted with the new STC952 seal (which does look far too big...). I thought I had managed to get it into place ok but having taken off the dashboard I noticed the rubber didn't form a good seal with the bulkhead. Having tried again and again I found the only way to get the seal to fit into place was to use some trim fix to stick the seal to the heater box. I also used much longer bolts than came out of the bottom fixing on the box in order to give me a fighting chance of getting the box into place, swapping them for smaller bolts one at a time once the box was tight. Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2014 Share Posted April 21, 2014 STC952 is correct for all inc 300tdi models see item 2 in page 624 in http://www.retroanaconda.com/landrover/parts_books/110/7_exhaust_cooling_heating_p580-666.pdf it fits on the outside of the duct which then fits in the dash hole. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 21, 2014 Share Posted April 21, 2014 I changed my seal today when I changed the matrix. I glued it into place as the original was glued from the factory. I managed to get the two bottom bolts in but the top bolts would get nowhere near until I got the help of Mr Ratchet Strap. Mo Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2014 Share Posted April 21, 2014 I must get a new seal for my heater box too, last time the heater was out the seal was just about reusable. Quote Link to comment Share on other sites More sharing options...
