Overdrive for lt230 and an auto transmission
94Discovery
Hello All
I am doing a volvo portal conversion on my 94 discovery and i need an overdrive
After using Ashcroft calculator i ended with 3500 rpm at 100 km ,i have the 7.14 c303 axles.37inch tires.
If i use the 1/1 tcase conversion i will drop to 2950rpm .
I contacted roamer drive and and they said that there kit is not compatible with Ashcroft 1/1 and it is not compatible with auto transmission.
Any idea how to resolve the problem without changing to R380 ?
Thank you
Naji M .
