camber pins when lifting, may be a stupid question
theoptimist
i have fitted 2 inch liftkits to 4 freelander 1s ,
2x L series
1x 2002 td4
1x 2005 td4
i have only ever fitted camber pins to the front, the adjuster on both track rods will need to be lenghtened approx 11 flats to get the front tracking about correct
also the front inner wings need cutting/welding so the the track rods dont fowl on full lock (with the suspension on full drop)
2x L series
1x 2002 td4
1x 2005 td4
brilliant thanks ramhead, the chap lifting it for me is going to cut the inner wing as far as he can before hitting the box section, did you need to go any further than that?
many thanks
sebastien
