jameshub Posted January 10, 2013 Share Posted January 10, 2013 I have the standard NATO towbar on my EX-MOD Defender and although i don't use a trailor much, does anyone know if you can use the standard trailor fixing i.e. the ball connector? or do i have to swap it or is there a modification kit? Thanks Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 10, 2013 Share Posted January 10, 2013 you would need to take off the nato hitch (and keep in a safe place) to fit a standard hitch. If you fit a dixon bate type drop plate kit with slidey thing, you can interchange fittings with one or two pins. Just remember to keep the slider in the truck when not in use otherwise the magpies will have them away. If it's an early ex-mil 80's then you need a pre 300tdi kit 1998 year. as crossmember holes are bit different Quote Link to comment Share on other sites More sharing options...
