need4speed Posted January 11, 2013 Share Posted January 11, 2013 Fitting my wiper motor to td5 bulkhead and discover 2 holes. What are they for? Ive encircled the holes in question in the pic below. I think one of them is windscreen washer tube?? Should i just blank the other off, or is there something else that goes through there? Quote Link to comment Share on other sites More sharing options...
chadler Posted January 11, 2013 Share Posted January 11, 2013 Front and rear washer tubes methinks Quote Link to comment Share on other sites More sharing options...
western Posted January 11, 2013 Share Posted January 11, 2013 washers tubing comes through higher up into the under screen vent area.via the oval grommet hole, just what feels like 2 blank plastic grommets in those 2 lower holes on my 110 but can't see them in the parts lists. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted January 11, 2013 Share Posted January 11, 2013 Yes they are for the washer tubes, on a 300 TDi bulkhead anyway! Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 12, 2013 Share Posted January 12, 2013 I noticed them on my TD5 bulkhead but just presumed they were for air con models. I went with washer tube through the oval hole further up as western suggested. Maybe i best remember to blank them holes or the passenger could end up with wet feet. Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 12, 2013 Author Share Posted January 12, 2013 On my bulkhead i have no hole further up so i guess they are front and rear washer tube holes as suggested earlier. Im not bothering with rear wash so i'll blank one off. Thanks fellas. Quote Link to comment Share on other sites More sharing options...
western Posted January 12, 2013 Share Posted January 12, 2013 so is that your bulkhead in the photo in your original post ? or did you use another photo for illustration. the oval hole is there above the heater square hole, it should have a big 3 hole grommet in it for the wiring from dash to heater/left front lights to pass through, my washer ubing is routed through it too. Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 12, 2013 Author Share Posted January 12, 2013 No thats not my bulkhead Ralph. I wasnt near my 110 when i posted so used that photo for illustration only. Im using td5 bulkhead along with td5 harness so i dont have the big 3 grommet plate thing. Quote Link to comment Share on other sites More sharing options...
western Posted January 12, 2013 Share Posted January 12, 2013 Cheers, that clears up my confusion. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 12, 2013 Share Posted January 12, 2013 Iv got a td5 bulkhead too and i have the oval hole, the plastic 3 hole plate came from my old td bulkhead. There are 2 of these ovals and 2 plastic plates on it at similar areas each side. Quote Link to comment Share on other sites More sharing options...
bluehaze Posted January 13, 2013 Share Posted January 13, 2013 I have a TD5 bulkhead and both of those small holes have plastic bungs in them. Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 13, 2013 Author Share Posted January 13, 2013 So the question then that begs to be asked is.....where the hell do you washer tubes go? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 13, 2013 Share Posted January 13, 2013 Think it depends what the chap on the assembly line was feeling like on the day. Or the spec of the vehicle etc. All the vehicles I've seen have had the washer tubes through those two holes. Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2013 Share Posted January 14, 2013 Fitting my wiper motor to td5 bulkhead and discover 2 holes. What are they for?Ive encircled the holes in question in the pic below. I think one of them is windscreen washer tube?? Should i just blank the other off, or is there something else that goes through there? Bulkhead010.JPG see this thread http://forums.lr4x4.com/index.php?showtopic=74871 2nd photo shows washer pipe through the inner hole below wiper motor, & in my defender workshop manual [200tdi] a drawing shows the same thing. Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 15, 2013 Author Share Posted January 15, 2013 Why thanks for refreshing my memory Ralph! Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2013 Share Posted January 15, 2013 your welcome, I was looking for wiper motor wiring & soon as I saw the drawing in my manual, thought that looks familiar, glad it helped. Quote Link to comment Share on other sites More sharing options...
