Japstick Posted January 14, 2013 Share Posted January 14, 2013 I'm looking to fit an oil pressure gauge to my 3.5 V8. Do I have to put in a T-piece to use the port the pressure switch is in at the moment or can I use one of the other ports on the filter housing?There isn't much clearance between the filter housing and the steering box, so I'm hoping one of the other ports also tap into the outlet side from the filter. Here is a piccie: Can I use the port indicated? Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2013 Share Posted January 14, 2013 this parts diagram might help, http://www.numcat.ru/landrover/p/31/53371/ looks to me the big plug you've arrowed is for the oil pressure gauge sender Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted January 15, 2013 Share Posted January 15, 2013 I'd love to know the answer to that too - and a recomednation for an easy (easy for mechanically challenged peopel like me) to fit oil pressure guage kit Quote Link to comment Share on other sites More sharing options...
Doctorvaltar Posted January 16, 2013 Share Posted January 16, 2013 On my v8 I added a oil pressure sender to run a gauge in addition to the pressure switch that goes the oil pressure light on the warning panel. I also added a oil temperature sender to run temp gauge. So I've got quite a few senders and switches down there! I took an old pump housing apart to see how the oil galleries were set up and it just required some adapters to be made to replace some of the blanking bolts that are fitted. One of the big bolts holds in the pressure relief spring so leave that alone but from memory all of the other ones can be removed a be replaced with adapters and sender units. I can get some pictures over if you like? Quote Link to comment Share on other sites More sharing options...
Japstick Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks Western. It certainly looks like it lines up with that port. I'm not sure, but something in the back of my mind says when the 3.5 V8 is in a range rover, that they are fitted with an oil pressure guage as standard. Can anyone confirm this and if so which port is the sender on? Quote Link to comment Share on other sites More sharing options...
Japstick Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks Doctorvaltar. I was hoping that it was easier than adding t-pieces or remote t-pieces. A couple of piccies would be great just to see where you have put what Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted January 17, 2013 Share Posted January 17, 2013 (edited) Thanks Western. It certainly looks like it lines up with that port.I'm not sure, but something in the back of my mind says when the 3.5 V8 is in a range rover, that they are fitted with an oil pressure guage as standard. Can anyone confirm this and if so which port is the sender on? "My 'A' reg 3.5 RR had both oil temp and oil pressure gauges (plus pressure warning lamp). The oil temp gauge sender was in the sump. Standard fit back then." Edited January 17, 2013 by western Quote Link to comment Share on other sites More sharing options...
Japstick Posted January 19, 2013 Author Share Posted January 19, 2013 G4FUJ - do you know which port the pressure sender was on? Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted January 20, 2013 Share Posted January 20, 2013 Unfortunately, it was a long time ago. Did have a quick look back through some old photos, but can't find where it was fitted, sorry! Quote Link to comment Share on other sites More sharing options...
Japstick Posted January 23, 2013 Author Share Posted January 23, 2013 It has been confirmed to me that the port indicated above is indeed used on V8 rangies for their oil pressure senders. So I'm going to fit the sender to this port. Quote Link to comment Share on other sites More sharing options...
