wingnut1 Posted January 16, 2013 Share Posted January 16, 2013 Hello. has anyone come across a electric pump to replace the mechanical lift pump on a 300 TDI engine .I have been looking at a pierburg pump fitted to the later range rovers, wondered if that would do the job or does it pump at to high a pressure.have any of you done this conversion , if so what did you use.any ideas would be useful.thanks.Neil. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted January 16, 2013 Share Posted January 16, 2013 a simple facet electric pump intended for use on carburettor fed engines would do the job well. Question is why do you want to change from the mehanical pump? Quote Link to comment Share on other sites More sharing options...
wingnut1 Posted January 16, 2013 Author Share Posted January 16, 2013 the vehicle is only used a few times a year so the pump diafram seems to rot . Quote Link to comment Share on other sites More sharing options...
LiamC Posted January 17, 2013 Share Posted January 17, 2013 I had a problem with the mechanical pumps failing with hot vegetable oil, so I fitted an electric facet pump which has been fine so far. Quote Link to comment Share on other sites More sharing options...
TSD Posted January 18, 2013 Share Posted January 18, 2013 I used a 4psi Facet 'Posi Flow' pump, as the 300tdi lift pump doesnt seem to keep up with the TGV thirst. Been on there for a couple of years (probably 25k miles) with no problems. I left the mech pump in place, with a loop of pipe from input to output, just in case it still works when the Facet packs in, and to fill the hole in the block. Quote Link to comment Share on other sites More sharing options...
