Phil Posted January 17, 2013 Share Posted January 17, 2013 For some time I've noticed a quite load, rapid and annoying ticking noise from the bulkhead/dashboard/transmission tunnel when the engine's under some load at revs over whatever it takes to do 60mph in 5th gear. The noise is a bit like the sound you get putting a playing card through the spokes of a bike wheel, and the speed of the ticking is constant. I've discovered the noise goes away if I press the clutch pedal just to the point where it starts to move the clutch. Obviously I can't drive round like that, so where should I look for the source of the noise? Thanks in advance, Phil. Quote Link to comment Share on other sites More sharing options...
defender dave Posted January 17, 2013 Share Posted January 17, 2013 is it a chirping sound if so that's normally a uj . Quote Link to comment Share on other sites More sharing options...
Phil Posted January 17, 2013 Author Share Posted January 17, 2013 is it a chirping sound if so that's normally a uj . No, Dave, it isn't a chirping sound and it's not a UJ. Thanks anyway, Phil. Quote Link to comment Share on other sites More sharing options...
Reiny Posted January 18, 2013 Share Posted January 18, 2013 Mine has been doing it for a couple of years now. I'm leaving it be until it goes bang. Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2013 Share Posted January 18, 2013 if it goes away with the clutch pedal slightly pressed, sounds like a release bearing having a bad time. Quote Link to comment Share on other sites More sharing options...
Phil Posted January 18, 2013 Author Share Posted January 18, 2013 Reiny, I think I'll go bang if I have to listen to it much longer! Ralph, thanks for your suggestion, I hadn't thought of the release bearing. I'm struggling to grasp how it would make that noise in those driving conditions. Is there any way of checking it without dismantling the car? Phil. Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2013 Share Posted January 18, 2013 no way to examine it without splitting the engine/gearbox joint. Quote Link to comment Share on other sites More sharing options...
Phil Posted January 18, 2013 Author Share Posted January 18, 2013 I thought that might be the case! What other symptoms could I look for that would confirm it's the bearing? Also, is there any part of the hydraulic linkage that's prone to rattling (ever hopeful!)? Thanks again, Phil. Quote Link to comment Share on other sites More sharing options...
Phil Posted January 19, 2013 Author Share Posted January 19, 2013 Right, sorted it! It was the hydraulic pipe making contact with the bulkhead. Hard to find but easy (and best of all cheap) to fix. Thanks to all, Phil. Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2013 Share Posted January 19, 2013 good news & a no cost fix, which we all like. Quote Link to comment Share on other sites More sharing options...
