heater matrix change on discovery 300tdi
davyd8899
hi all i come seeking wisdom once again!!!
the blowers in my 300tdi disco is blowing stone old when fully warmed up. it has always done this
so after a new head, gasket, bolts etc (it needed his anyways!) am assuming the heater matrix is shot.
there are no air locks etc.
so how easy is it to replace the matrix??
look forwards to all your responces.
I did mine a couple of years ago. Think of it this way, when they build a Disco, you start with a bare shell and the next thing they put in is the heater matrix! It took me a day and a half to replace the matrix on mine. The instruction in the manual are very good, there's just a lot of stuff to take out!
Cheers
Peter
sounds like it could be blocked, have you tried some cooling system flush first? or maybe try back flushing it with a hose? it's not a major hassle, dash has to come out, but the heater unit itself can be left in place, very fiddly getting the pipes to reseal afterwards though.
flaps are moving, there is a definate and noticable change of air flow when turning the heater control from hot to cold.
would this happen even if it was blocked??
if i took the pipes off the head and the metal pipe and blew through with a hose would this clear any blockage??
all thoughts greatfully recieved
hi
i did a audi 80 a few weeks ago with the same problem
and with both the pipes on the same header tank of the rad it was a pain to clear but
the owner had a tin of halfords rad flush so i blocked 1 pipe and filled the heater through the other pipe
and left it for a hour or so and it did the job
worth a try before taking the dash out
hth
have just blew through the heater with a hose, flushed the system and............................................
Stone cold air!!!
so guessing the matrix is shot???
Only two thing to go wrong with a heater matrix, it is leaking or the water flow is blocked, so are the flow and return hoses hot indicating there is a flow through the matrix, if so then is must be the airflow/blending controls or dampers not working which has been known according to the forums..
As diesel run cool is the engine reaching it proper running tempreture.
the pipes are geting warm but wouldnt describe them as hot.
temperature guage reads smack in the middle.
sticking thermostat maybe??
The pipes should be as near hot as the top hose. The heater temp is not reliant on the thermostat being open or closed but only on the engine/coolent temp you should have some warmth even before the thermostate has even opened. Have you removed the fan or blanked off the lower half of the rad.
Take the hoses and steel pipes of the engine for inspection first - they're easy enough to do, but he matrix is harder to get at. The steel pipe that runs along the top of the head rusts up and the hoses may have collapsed internally. I'd second the idea of back-flushing the matrix and soaking it in rad flush for a while to dissolve deposits before stripping it out.
