Heater Fault
Would really appreciate any help or suggestions with this as I really don't have the first idea when it comes to electrical problems.
My 90 originally had air-con and therefore has unfamiliar heater controls when compared to other 90s, the fan has 3 speeds and the third (fastest) has never worked. With the wet/cold weather recently the windows seem to be constantly covered in condensation. The V8 produces plenty of heat so it would be really, really good to have a bit more 'blow' to get that heat into the vehicle and onto the windows!
I've done a little research and have come to the conclusion that it could be down to a failed resistor? Now, does anyone know A)where the hell this lives? And B) can it be changed and if so how? or C)anything else I can do? - I plan to check and seal any leaks from the blower motor through to the vents but obviously if I had top speed working on the motor, that would improve things hugely.
Any help/advice would be great as the condensation is driving me crazy!!
assuming you have the underdash air con fitted, the resistor is item 5 in http://www.numcat.ru/landrover/p/31/52937/ might be a air con duct remove to access the motor/resistor.
if it's the vertical in dash unit, resistor maybe in the control panel in http://www.numcat.ru/landrover/p/31/52944/ or within the evaporater unit http://www.numcat.ru/landrover/p/31/52939/
Many thanks for your input, gives me something else to work with in my research! Looking at your links, it would appear I have the vertical dash unit. I take it there was two air con systems fitted to early 90s/110s - what do these names mean - 'underdash' and 'vertical'?
Yes I definitely have the 'vertical' variety!
I guess the resistor is in that box of tricks (item 4 in diagram) and I wouldn't want or know how to take that apart. Would a new one still be available I wonder? Even if it were it looks like it'd be over £200.
So, fixing it or replacing it do not appear to be options. So does anyone know if I could fit the Rover 100 fan speed control and ballast resister - I understand it is a popular mod with 90s/110s with the convential heating/ventilation?
looking at the air con wiring diagrams/section in my workshop manual it shows the resistor block with 4 wires
red
orange
blue
yellow/black trace
the yellow/black goes to the relay, the other 3 to the control switch unit.
for left hand drive vehicles it says to remove the resistor block, open bonnet, detach the blower motor wiring connector, remove the self tapping screw & lift out the resistor block,
for right hand drive, open bonnet, on the left [vehicles left] of the engine bay, the resistor block has 2 hex head bolts securing it to the left wing upper inner edge approx in line with the wing top air intake cover, remove the bolts/disconnect the plug & lift out the resistor block.
item 1 in http://www.numcat.ru/landrover/p/31/52815/ is the resistor for RHD vehicles.
no picture of the actual resistor but here for just over 11 quid http://www.brit-car.co.uk/product.php?xProd=140732 or here for a bit less cash http://www.lrseries.com/shop/product/listing/2348/AEU1747-RESISTOR.html?search=AEU1747&page=1
Western you are a legend! Really appraeciate you taking the time to look this up - top bloke! Many, many thanks!
Looks pretty straight forward, and inexpensive too! What is the likelyhood the reason speed 3 isn't working being a failed resistor? Do you know if there are any tests I can do to confirm it's the resistor that's failed?
in the air con fault diagnosis chart in my workshop manual, it says
blower motor with less than 3 speeds, inspect resistor block, -- resistor block defective = replace
or resistor block OK -- inspect blower switch & replace switch if defective,
so yes a duff resistor will knock out 1 or more fan speeds.
manual doesn't give any test for dead resistor, just the info above, glad it's all been useful.
hth :i-m_so_happy:
