what size ??
can some one please tell me what size jubilee for the fuel filler pipe to tank , also after rear tub is on any guides on running order for things to put on in order , new build , so dont know the 90 very well only discos , thanks .
Edited by western
Leave rear tub loose (fit rear sides)with all bolts in place then fit the bulkhead, again loose as you need to trial to trial fit the doors and do the alignment to get the doors gaps correct. A lot of trial and error but it is worth taking the time to get it correct. Buy a set of mixed jubilee clips - you will need them. I would then fit the windscreen and roof again checking the door gaps as you go. well this is how I did my one.....
