AT tyres about 32" not remoulds
jad
 Share
Hi Everyone
Does anyone know what AT tyres are available that measure about 32 inch? I currently have 235/85/16 insa turbo special tracks that measure 32 front to back and 31 top to bottom. I want to replace them with something a lot more road friendly as I now dont do as much off roading as I used to and when I do its normally green laning than play days.
I was looking at 285/75/16 general grabber AT's which are a little larger ~33" but I will have to get some less offset and wider rims (currently on a 7" modular with I think a +8mm offset) This would obviously reduce my turning circle which I am not bothered about as I wont be doing any trialing with it.
I have read though that the 235/85/16 general grabber AT measures up at 32.5" which would be ideal. Can anyone confirm this?
If anyone has any other suggestions that would be much appreciated.
Thanks
Jad
They are slightly smaller and theoretically only 2mm difference to the 235's. I had my dads coopers ST's on before in 265 but they looked a lot smaller than the insa's. I dont want to go any smaller really.
Jad
Tyre diameter will vary a small amount between manufacturers, the pressure they are at when you measure them, how worn, and so on.
BFG ATs in 265/75x15 would be a very good size, and will not foul the arches. The proportions give good road holding too.
 Share
