zoltan Posted January 22, 2013 Share Posted January 22, 2013 Feel free to lambast me if I have posted this in the wrong forum. I have a petrol Eberspacher Hydronic for my truck's living quarters and it won't start. I suspect that now it has gone into lockout. I bought it from a well known auction site from a German fellow (couldn't find any petrol ones in UK) and assumed it was OK. That was several years ago and in the intervening time it has either deteriorated in storage or it was always duff. (It is a new installation to me) I've checked the wiring harness and all appears to be correct there. I have then pulled it partially apart to enable me to check that the components all function. From this the water pump (B4WS) is not responding to 12v. I've made absolutely sure it isn't failing due to low voltage as i know Ebers commonly fail to start from LV. At a pinch I can work it with an external electric water pump but that still won't help me with the locked out control module. Has anyone hacked one of these? I *could* take it go a dealer to get them to unlock it but I'm off on a trip on Friday and would quite like this thing working and a visit to a dealer really isn't in the spirit of this forum Anyone? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 22, 2013 Share Posted January 22, 2013 Have you looked on the eberspacher website it is very comprehensive with downloadable manuals. Mike Quote Link to comment Share on other sites More sharing options...
zoltan Posted January 22, 2013 Author Share Posted January 22, 2013 Trawled through dozens of pages on Espar.com. manuals very good but same story: it is a software lockout so it is a trip to the dealers or buy the diagnostic reset tool for £300 I want a button on the side so that when it is -20 in the middle of no-where I can keep warm. Unless I can find a way to bypass/gain control of this I'm reluctant to have this in the truck. I understand the Webasto Thermo-top doesn't have this lockout feature Quote Link to comment Share on other sites More sharing options...
TSD Posted January 22, 2013 Share Posted January 22, 2013 IIRC Eberspacher service software is available on the web - don't know if it covers your unit though. You need a k-line interface to connect to the unit. I am told that some of the OBD - PC interfaces can do this, but I've never got as far as trying it. I have a pcb here I designed for an Eberspacher interface, but I never got around to building it as I found the problem with my heater in the meantime. Webasto heaters can be recovered from some kinds of lockout by removing one of the fuses. For safety reasons it only works for things like 'no start' and not for 'overheat'. For instance... Hardware and Software Quote Link to comment Share on other sites More sharing options...
zoltan Posted January 22, 2013 Author Share Posted January 22, 2013 I bit the bullet and took my heater in to the local dealer who were extremely helpful: they ran it on the diagnostics and it hadn't locked out which was good news. No arsey attitude and did it while I waited. I have a simple water pump failure which I can replace and the fan was excessively noisy. They didn't make any charge for checking so I ordered the parts through them when I got back home. Should be here on a next day service so thanks to South Eastern Auto Electrical Services in Maidstone, cinderella will be going to the ball afterall Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 22, 2013 Share Posted January 22, 2013 Cinderella will be warm to Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 22, 2013 Share Posted January 22, 2013 Always good to hear of helpful attitudes from dealers. Happy toasty travels :-) Quote Link to comment Share on other sites More sharing options...
