brent 3045 Posted January 24, 2013 Share Posted January 24, 2013 Does a normal 52mm socket fit the wheels to replace the bearings? Thanks in advance Quote Link to comment Share on other sites More sharing options...
western Posted January 24, 2013 Share Posted January 24, 2013 a 52mm socket will fit you might need a deep one though, I use a box spanner like this is http://shop.difflock.com/land-rover-spanner-plain-p-33.html Quote Link to comment Share on other sites More sharing options...
richardjm Posted January 25, 2013 Share Posted January 25, 2013 So do I, at a cost of £3-98 + VAT from Paddock (ref 606435). Quote Link to comment Share on other sites More sharing options...
muddy Posted January 25, 2013 Share Posted January 25, 2013 I have a 52mm shallow ( which at 52mm is deep ish) impact socket that is essential for post Td5 vehicles. I wasn't espensive really about 15-20 quid iirc. Will. Quote Link to comment Share on other sites More sharing options...
Disco1tdi Posted January 25, 2013 Share Posted January 25, 2013 "SX010 BRAND NEW SEALEY 52MM IMPACT SOCKET 1/2" SQUARE DRIVE" from ebay worked well for me.... £11.99 delivered. Yes, the box spanners are cheaper (if you search around), but for the sake of a few quid, why not have a much better tool? (assuming you have a breaker bar/torque wrench already) Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 25, 2013 Share Posted January 25, 2013 "SX010 BRAND NEW SEALEY 52MM IMPACT SOCKET 1/2" SQUARE DRIVE" from ebay worked well for me.... £11.99 delivered.Yes, the box spanners are cheaper (if you search around), but for the sake of a few quid, why not have a much better tool? (assuming you have a breaker bar/torque wrench already) IMO the box spanner is a much superior tool as you can use both hands on the tommy bar when adjusting the wheel bearings. Why is a breaker bar needed ? The hub nuts shouldn't be that tight. I often use water pump pliers to set wheel bearings Quote Link to comment Share on other sites More sharing options...
muddy Posted January 25, 2013 Share Posted January 25, 2013 Td5 onwards use a crush tube/spacer to set the bearing preload and a F off stake nut to keep it all in place, you need at least a breaker bar to undo them hence the need for the proper socket, however I only use that to remove the rather gash setup IMHO and then fit the pre td5 setup using a box spanner to set the preload. Will. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 25, 2013 Share Posted January 25, 2013 Td5 onwards use a crush tube/spacer to set the bearing preload and a F off stake nut to keep it all in place, you need at least a breaker bar to undo them hence the need for the proper socket, however I only use that to remove the rather gash setup IMHO and then fit the pre td5 setup using a box spanner to set the preload.Will. That's what I would be doing. So please how do you convert back so I can try to remember it. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 25, 2013 Share Posted January 25, 2013 Remove the crush spacer, refit with the rest of the bits for the pre-Td5 setup. Thrust washer, lock tab washer and the extra nut Quote Link to comment Share on other sites More sharing options...
UdderlyOffroad Posted January 25, 2013 Share Posted January 25, 2013 Socket is definitely the way to go, grips the nuts better & less prone to slippage if some cretin has done it up to VFT! Quote Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2013 Share Posted January 25, 2013 I second (or what ever number it is) the 52mm socket, I have both and although I have a TD5 so need to set the torque on other trucks I still use the socket to release more stubborn hub nuts especially if the bearing has given up and started to weld it's self to things. Jason. Quote Link to comment Share on other sites More sharing options...
jbs Posted January 26, 2013 Share Posted January 26, 2013 There is a certain torque setting when doing the wheel bearings on any land rover product and after I welded a plate with an old 1/2 inch socket on it to my box spanner that allowed me to get a torque setting per say, however now I have bought a proper deep impact socket I get the full benefit of proper torque settings and my wheel bearings don't need "adjusting" half as much as they used to just by doing it by feel-I run those challenger wheels and Goodyear wrangler MTRs on my 90 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 26, 2013 Share Posted January 26, 2013 There is a torque setting, but I do mine by feel and the only trouble I've had was muddy water ingress with shagged stub axles. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted January 26, 2013 Share Posted January 26, 2013 Torque setting. That's a very modern thing. I was taught to tighten by feel. I still do. When working on twin wheel Transit ambulances I found that for the front wheel bearings that an 1 1/8" socket with a 3/8" drive brace was the correct torque for the front hub bearings.... As I've only done 104,000 miles with my Defender. I'm afraid I can't say if the way I set hub bearings is wrong. All I can say is I've yet to change a hub bearing. In fact the two sets I carry as spares came from the rear axle of my Range Rover. I found the 52mm socket very heave and unstable to use. As well as not being deep enough Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 26, 2013 Share Posted January 26, 2013 When I get round to it, my socket just needs a tiny bit taking out of the back of it on the lathe. Then it will be perfect Quote Link to comment Share on other sites More sharing options...
